turbo on stock b18c1???
Old Sep 12, 2007 | 07:06 PM
sleeper99ex's Avatar
Default turbo on stock b18c1???
would it be a good idea to turbo a stock b18c1? if so how much boost would work for an every day driver and what kind of setup am i looking for?
Old Sep 12, 2007 | 08:15 PM
xramseyx's Avatar
Default RE: turbo on stock b18c1???
Personally, if you have the money.... spend it. If your trying to build up a turbo kit and run it on your stock internals... TUNE! spend all your money and some you dont have on a tune. Especially if its gonna be your DD. Get a turbo with an internal wastegate... set low more than likely and just run that. RESEARCH RESEARCH RESEARCH.... those are all the tips you need.
Old Sep 12, 2007 | 11:45 PM
gsumano's Avatar
about how much boost you can run safely depends on the turbo.
Old Sep 13, 2007 | 03:58 AM
well what i origanally wanted to do was try to build a 300hp all motor but after some reserch i have found that is next to imposable and even if it could happen it would cost twice as much as a turbo. i have done alot of rebuilds but never have i messed with a turbo. i know this much i would like to push no more than 12 psi.
Old Sep 13, 2007 | 05:50 AM
RCJr9186's Avatar
it all depends on the turbo my friend.... you can run 16lbs on a t25 and run 16lbs on a t88 and see 9-10x the difference.... here's a good way to look at it.
if you put 25psi of water pressure through a garden hose you have a nice litle steam.... but if you put 25psi of water pressur through a fire engine hose you have a WHOLE LOT of water. it's the same deal with a turbo. but i am curious about the same question as well.
guys lets say for $hits and giggles that he's running a nice sized 16g like the EVOIII Big 16g. how much boost could you safely run on it and how much HP would it put down? on a DD (yes we kno it has to be a VERY good tune)
Xx95civicxX
Mar 24, 2010 04:20 AM
EGB16A
Feb 27, 2008 03:47 PM
0xyGen
Feb 20, 2008 04:29 PM
Fishey
Aug 24, 2006 05:22 PM
MrTen
23
Feb 14, 2006 12:48 AM
