Rust
Old Sep 16, 2007 | 12:17 PM
xtremerunnerars's Avatar
Default Rust
I've got a bunch of rust in a few spots on my car and I'm wondering how to get rid of it. This rust was all there when I got the car (sister got a newer car.)
http://flickr.com/photos/11361360@N0...7602036482448/ There's a link to the pics of the rust that I took. With another winter coming up, I'm wondering whether I should get this taken care of or not. I'll won't have the car for all that longer so I don't want to spend a whole lot of money paying a shop to do it. If it would be relatively cheap (~100-150???) I may spring for it, but otherwise I guess it's fine.
Old Sep 16, 2007 | 12:22 PM
civic_burns_all's Avatar
Default RE: Rust
use some WD-40 on it?
Old Sep 16, 2007 | 12:25 PM
Masonn's Avatar
Default RE: Rust
Good luck on the price. Rust repair is fairly expensive. I have 2 rust spots on my car, about the size of 2 coins in each spot. They gave me a quote of upwards of 2 grand...
Old Sep 16, 2007 | 12:37 PM
cyberx32's Avatar
Default RE: Rust
It really depends on how much metal the rust ate through, the faster you act the better.
Old Sep 16, 2007 | 03:00 PM
thisisoriginal's Avatar
Default RE: Rust
well if you aren't going to have it much longer dont worry about it. But if you want to fix it a bit for selling purposes, id say figure how much you could get for the car after you fix the rust, and how much you can with the rust, because you may end up putting a 100 or so into it, but then you won't even get that out of the selling price either way.
Old Sep 17, 2007 | 10:41 PM
Kommando's Avatar
Default RE: Rust
ORIGINAL: xtremerunnerars
If it hasn't eaten through, get some POR-15 and follow the directions for applying it. If it HAS eaten down pretty far, you'll want to cut out the bad metal and weld in new metal. I'd look at replacing the whole panel if you want it to look nice. If it's on the unibody, I hope you know how to weld.
cbaber
Jan 17, 2008 12:26 PM
superchixor
Aug 10, 2005 09:59 AM
thebrodizzle
Aug 4, 2005 03:36 AM
mill$civic
Jul 20, 2005 12:17 PM
