Antenna
Old Nov 1, 2007 | 05:30 PM
wirphotos's Avatar
Default Antenna
I have XM Satellite radio installed in my car and thats usually all I listen to. At times I want to tune to just the regular FM radio. I think the antennas on civics look retarded when you extend them, so I keep mine pushed down. Is there any aftermarket antenna that any of you have used that is short and gets great reception?
Old Nov 1, 2007 | 05:53 PM
95civic1.6l's Avatar
Default RE: Antenna
its going to look weird having 2 antenna's. But if you only listen to it at times i would just do with what you have. your going to have to run new wiring to the new antenna and drill a hole in your body. U sure you want to get another antenna even though you don't use the radio alot?
Old Nov 1, 2007 | 06:41 PM
wirphotos's Avatar
Default RE: Antenna
I would be replacing the factory antenna. The Satellite Antenna is already on the car. I have 2 antennas on the car already. Just looking to replace the factory antenna with a short stubby one that fits in the same spot as the factory one.
Old Nov 1, 2007 | 07:06 PM
Default RE: Antenna
so now you wanna have 3 antennas on your car. 2 of them that will stick out of your car. even though you don't really listen to the radio?
Old Nov 2, 2007 | 08:02 AM
wirphotos's Avatar
Default RE: Antenna
Let me explain this in so everyone can understand it.......dropping down to 1st grade leve.
I have 2 antenna's on my car, the factory one and the satellite radioantenna. I am looking at removing the factory antenna which would give me 1 antenna.... still with me? And buying a short stubby antenna to put where the factory antenna was orginally which would give me 2 antennas.
Understand?
Old Nov 2, 2007 | 10:02 AM
my94civic's Avatar
Default RE: Antenna
hey wirphotos,
over here in the uk there are a lot of modders (ricers) than replace their antenna with a short stubby one, they are called bee sting's, i suppose it is a bit ricer, but if it suits your needs...
Old Nov 2, 2007 | 11:28 AM
Kov's Avatar
Kov
Default RE: Antenna
i have the oemblock plate over the stock location. I then went and bought an antenna that I mounted on the inside of the rear window. It doesnt get as good as reception as the regular antenna, but it works. All i really need to do still is get the antenna signal booster and it will be 100x better.
I was like you and dindt like the stock one, so this is what i did.
Old Nov 2, 2007 | 11:56 AM
my94civic's Avatar
Default RE: Antenna
i still have my standard antenna, i dont think its that bad, plus i never listen to the radio so its not up all that often, so wasnt really a problem for me. For example the Peugeot 106 the standard antenna on that is probably the length of the car itself...
soulshadow2233
Dec 20, 2006 08:41 PM
zz28zz
Oct 7, 2005 10:23 PM
Novahawk13
Jul 20, 2005 12:20 PM
ratbastrd
Apr 18, 2005 08:48 PM
RandomCharacter
Mar 26, 2005 12:37 AM
