How do you get rid of all the rattling other than turning volume down? (98 EX Coupe)
Old Dec 23, 2007 | 05:26 PM
Steven T's Avatar
Default How do you get rid of all the rattling other than turning volume down? (98 EX Coupe)
I just ordered a new cadence setup for my EX coupe. I know it's going to rattle and sound ridiculous (I hate that noise).
What's the quickest way to get rid of it? where's it coming from?
Old Dec 23, 2007 | 06:11 PM
civicduty96's Avatar
Default RE: How do you get rid of all the rattling other than turning volume down? (98 EX Coupe)
dynamat your trunk lid.... tighten the trunk latch and taillights..... the torsion bar for the trunk lid rattles also... hope this helps
Old Dec 23, 2007 | 06:28 PM
sir_bobos's Avatar
You might want to Dynamat your shelf thing in the back seat to if you happen to put in 6X9's. I'm planning on doing this since I'll have it removed, it's started to rattle like crazy. Oh and new stuff will come loose over time so take it as it comes.
Old Dec 23, 2007 | 06:57 PM
well kinda disagree with dynomating everything... cause not everything rattles....
find the rattle itself and then fix it...
most the time NEW CLIPS on those interior panels youve removed once or twice or more can help alot! cause after pulled so many times they dont hold as strong and of course rattle..
Old Dec 23, 2007 | 07:34 PM
kokasian's Avatar
weather stripping on the deges of all your plastic interior panels helps a lot too, thats where most of my rattles were with just the noise from my exhaust
Old Dec 24, 2007 | 08:24 PM
Vilex's Avatar
I'll tell you this now, make sure you have your rear license plate bolted down pretty good. I only got 2 screws on the top of mine, and the bottom rattles HORRIBLE.. I didn't notice it until someone mentioned it, and I got out and listened.. Wow, it was so annoying. Then I pushed the bottom down, and it sounded ALOT better.
Well, currently.. I have my sub facing my interior, instead of having it face the trunk. I think that helps a little, since the air isn't focused on the trunk and everything itself.. Though, i've had many compliments on the 'massage' it gives people in the back seat [8D].
Old Dec 25, 2007 | 08:05 PM
s0ulj3r's Avatar
ORIGINAL: Vilex
actually, the "massage" would be better if they were turned around, it pushed more air that way compared to the other way.. even though its pushing it directly towards the seats when its facing your interior, its still a huge difference. Do you pull your rear seats down when no ones back there? try it.. its a HUGE difference
Old Dec 25, 2007 | 08:06 PM
s0ulj3r's Avatar
and if the rattling isnt findable, just either get used to it, or spray foam that ****! =P
Old Dec 27, 2007 | 11:40 AM
sde780's Avatar
I got $3 worth of weather stripping at walmart, the foam kind, and did my whole rear shelf along the edge, and a whole bunch in the middle. It helped a bit...
windcalmer
Dec 4, 2006 03:55 PM
cowsgonemadd3
Sep 1, 2006 10:08 PM
ef4life
Apr 21, 2006 01:14 AM
Vexorg
Apr 19, 2006 09:08 PM
Shandles
Dec 20, 2005 04:33 PM
