d16y7 turbo over reving problem
Old Mar 7, 2008 | 02:22 AM
civic_turbo's Avatar
Default d16y7 turbo over reving problem
I havea d16y7 turbo.When i over rev it at 3000rpm it releases pressure automatically through the blow of valve. after i reach 3000rpm the car keeps jerking and releasing pressure. i tried changing the boost withthe boost controller, but it does not go over than 8psi. Is it because the ecu is programmed to run a 8psi?Somebody please help
Old Mar 7, 2008 | 05:30 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: d16y7 turbo over reving problem
Could be a weak BOV spring... or something related.
Old Mar 7, 2008 | 07:08 AM
riceburner700's Avatar
what bov are you running. i know on some you have to change out the spring
Old Mar 7, 2008 | 09:03 AM
arust45's Avatar
Mine did the same when it had a crap seal. Check your welds and gasket.
________
Nexium lawsuit information
cjy01
14
Jul 10, 2011 03:38 PM
nightrider46
May 24, 2007 11:56 AM
H22
Nov 20, 2006 05:46 PM
RoundEyeRacing1904
17
Aug 3, 2006 11:40 PM
Zer0Ale
Jul 20, 2006 12:48 AM
