Acts like water in the gas, but not.
Old Apr 8, 2008 | 05:21 PM
me262dave's Avatar
Default Acts like water in the gas, but not.
For the last three months my 90 civic LX has acted like it has water in the gas. I know it's not water, but the feeling is the same as a slug of water going through an engine. At first it was just once in a while, but it is now happening all the time and it is starting to just die unexpectedly.
I have no trouble codes showing. I am new to honda and do not know their quirks. the plugs are new, the wires older,
and the timing has not been checked in a while.
I did the master relay fix for random no start conditions, about two years ago. Is it possible that this is a symptom of a bad solder joint in the relay?
Thank You for your input.
Old Apr 8, 2008 | 06:16 PM
Default RE: Acts like water in the gas, but not.
Might be a clogged fuel filter or a faulty fuel pump.
Alternatively, the coil or igniter unit in the distributor is intermittently failing.
Also, here's how to set the ignition timing:
Old Apr 8, 2008 | 08:04 PM
If it gets worse the harder you step on the gas, seriously consider new wires. Don't use aftermarket wires; a lot of crappy ones out there.
relentlesstech
Jun 15, 2012 08:41 AM
PaulC
20
Sep 8, 2009 07:31 AM
scoob8000
Mar 19, 2009 04:11 PM
civic_burns_all
Sep 15, 2007 07:00 PM
Fiirkan
Aug 25, 2007 01:39 PM
