not a turbo
Well there's intake, headers, and exhuast, Port and polish, and well I really shouldn't say it but cams, you can do cams without a tune but I wouldn't suggest it, It would run better with a tune. You could also get a aftermarket intake manifold. hope that helps.
In addition to the I/H/E bolt-on mods, I've read that you can have your valves grinded to be more aerodynamic, allowing more head flow. I'm not sure if valve grinding is the right term to use, but basically you (or a machinist) thin out the valve stems and reshape the how the valve tapers. This is supposed to be across the rpm range HP. The service itself can be expensive--you need to pull the head off the block, then take it to a machine shop to get the valves individually modified (hopefully with a flow bench).
I'm just throwing this idea out there, I'm not sure how much it costs, but it could be pretty expensive.
addiction2bass
Feb 4, 2008 06:43 PM
liquidrider_3214
16
Aug 22, 2007 06:54 PM
eg9
May 22, 2006 04:43 PM
