Questions on sway bar install..
Old Apr 26, 2008 | 08:59 PM
tjbarne's Avatar
Default Questions on sway bar install..
I just got a beautiful '08 coupe EX-L Civic. I just bought a set of OEM Si sway bars (front and rear)off eBay. My question is: can the original sway bars be removed okay buy driving up on ramps, or will I have to raise the vehicle with a jack and put on jackstandsto take any weight/pressure off the suspension first. I also just put Si wheels on it, so I'm excited about the suspension mods to see if it will handle better. Also can I use the original links or will I need heavier ones with the Si sway bars...thanks, Thx
Old Apr 28, 2008 | 08:29 PM
Kommando's Avatar
Default RE: Questions on sway bar install..
You should be able to swap bars by using ramps. You'll need 2, one for each side, though.
If your current endlinks fit on the new bars, you should be able to re-use them. The strength/rigidity of the endlinks isn't an issue.
jprommel
Apr 28, 2008 04:28 AM
Big T
May 29, 2007 01:17 PM
FlipHKD720
Aug 12, 2006 03:28 PM
D16z6
May 22, 2006 09:24 AM
sonicOne
Oct 6, 2004 09:18 PM
