Tach wire...
Old May 3, 2008 | 03:26 PM
cdegard117's Avatar
Default Tach wire...
i got guages im putting in, one is a tachometer, butmy mechanic and icant find where the tach wire is in the engine bay. would any one here know, its an 07 civic ex. we tried calling the place but they dont know and honda wont tell us. help please , thanks
Old May 3, 2008 | 03:31 PM
Default RE: Tach wire...
On earlier model Civics, the blue wire attached to the ignition control module in the distributor provides the tachometer signal.
Old May 3, 2008 | 03:56 PM
cdegard117's Avatar
ya thats wut we were thinking, a good wiring diagram would help if anyone happens to have one.
Old May 3, 2008 | 05:17 PM
The blue wire is more than likely the one you want. Simply test by doing a quick temporary hook up to the new tach.
Old May 4, 2008 | 04:31 PM
cdegard117's Avatar
alright but where would that be
Old May 4, 2008 | 04:37 PM
The blue wire from the ICM in the distributor goes directly to the tachometer via one of the gauge assembly connectors. On my 97 Civic, the wire also branches to a connector in the engine compartment located on the extreme driver's side near the firewall. Look for this loose connector attached to a blue wire.
Old May 6, 2008 | 06:29 PM
the_turtle's Avatar
wait, 07's already have a tach on the dash, why would you want a different one? im assuming that its all controlled by the ecu, since the throttle is "drive by wire" im willing to bet that tach wire the older ones have has been completely eliminated. good luck with your hunt. if you make good friends with a honda service department employee, they can most likely help you. i recommend this because you can always find something to ask them.....
V8DIET
Aug 18, 2008 12:02 PM
xsdudztx
Aug 14, 2007 05:45 PM
seaton05261979
May 18, 2007 04:35 PM
racinmason
Nov 10, 2006 12:21 AM
dalifts
Dec 16, 2004 10:34 PM
