Low compression 97 1.6
Old May 19, 2008 | 08:21 PM
BLAZZ81's Avatar
Default Low compression 97 1.6
I know its on the #1 cylinderand its not the valves.
What do i need to fix? is there a kit?are any special tools needed to do the job?
I was told it can be done with the engine in the car but i need to swith out the tranny anyways soill just pull them both out.
the car has 150k on it, Any tips on what should be replaced while i have the engine and trans pulled?
Old May 19, 2008 | 08:29 PM
Default RE: Low compression 97 1.6
A wet versus dry compression test should be done to distinguish a bad piston ring from a blown head gasket.
Old May 19, 2008 | 08:43 PM
BLAZZ81's Avatar
When oil is added tothe cylindercompression is good.
mysighnature is not working?
http://cia-gamers.com/members/car.JPG
Old May 19, 2008 | 08:53 PM
Here's where to start:
http://hondatech.info/downloads/Auto/Manuals/Civic/
Is replacing the engine an option that you have considered?
Old May 19, 2008 | 09:41 PM
BLAZZ81's Avatar
I would rather fix this engine, I have already put in a new water pump and timeing belt.
And other then cylinder 1 it'sa good engine.
If itis cheaper to get a used enginethen maybe, but at a junk yard you dont know what your getting.
I have a Haynes Repair Manual its for..
civic 96-2000
cr-v 97-01
integra 94-2000
Iliketo get some help andtipsfrom the forums b4 the job, I plan to do this next weekend.
A manualcan't help with on hand question
rcgtsport
Jul 12, 2011 04:51 PM
siguy2000
Apr 23, 2008 05:15 PM
foress_89
Oct 8, 2007 09:04 PM
larsenracing
Mar 3, 2006 07:18 PM
nachoman
May 23, 2005 02:37 PM
