D16Y8 engine valve issues...
Old May 21, 2008 | 08:46 AM
pendletone's Avatar
Default D16Y8 engine valve issues...
I'm looking at buying a 96 Honda Civic from an owner who tells me they are having a "floating valve" issue. From what I've seen while the engine is running, it seems very weak and there is a smell of gas coming from the exhaust. The way it was explained to me was that it would take a couple hours to correct this issue.
Does anyone have any thoughts as to correcting this issue?
Ideally what I'm hoping to do is find a manual or a step-by-step breakdown of what I need to do to fix this. I'm no mechanic by any means, so please bare with me for any stupid questions.
Old May 21, 2008 | 09:07 AM
riceburner700's Avatar
Default RE: D16Y8 engine valve issues...
replacing valves might be easier for you to just take the head off and take it to a machine shop and let them do it. "floating" valves is when the engine has reved higher than factory redline and the valve spring cant keep the valve closed fast enought and then your valve makes slight contact with your pistons bending/breaking them hince lost of compression
Old May 21, 2008 | 09:15 AM
pendletone's Avatar
Any good place that I could find a manual to get that off then? I'm stranded in Germany with no hope of finding an english version...
Old May 21, 2008 | 01:49 PM
ou order like a chilton or haynes? they will tell you how to replace a bent valve
Old May 21, 2008 | 02:51 PM
ORIGINAL: pendletone
http://hondatech.info/downloads/Auto/Manuals/Civic/
tillis3
Oct 25, 2011 03:19 AM
Pojoman
Sep 25, 2009 02:52 AM
asechrist
Dec 22, 2008 05:49 AM
96redciv
Feb 15, 2008 05:18 PM
larryT
Jan 2, 2008 03:46 PM
