Valve adjust on an automatic valve adjust engine
Old Dec 20, 2008 | 01:40 PM
asechrist's Avatar
Default Valve adjust on an automatic valve adjust engine
Hello,
Is it possible to do a manul valve adjustment on an engine equipped with an automatic valve adjuster, if the adjuster does not seem to be functioning properly (i.e. it sounds as though there is a lot of valve lash)?
-Can an engine which has valves out of adjustment be loud sometimes, but not others?
Thanks,
Andy
Old Dec 20, 2008 | 01:49 PM
There's usually no place to adjust. The automatic valve lifters adjust themselves by filling with oil. So, insufficient oil pressure will prevent the valve lifters from working properly. If it is just one valve, the lifter is stuck and needs to be replaced.
Old Dec 20, 2008 | 02:57 PM
asechrist's Avatar
Thanks mk,
I do not have an oil pressure tester, but will try to borrow one form a neighbor. If it checks out Ok and I check the lifters, what is the best way to tell which one/ones are stuck?
Old Dec 22, 2008 | 05:49 AM
nasoj007's Avatar
Try some Wynn's Engine Tune-up (used to be called 'Lifter Medic'). Anytime I've had a lifter that was acting up I've thrown a can of this in and after a bit it's cleared things up.
http://www.wynns.ca/pages/english/e_...s-c-engine.asp
P.S. I guess the US gets different versions of Wynn's products so I think your equivalent is 'TUNE-UP TREATMENT CONCENTRATE'
http://www.wynnsusa.com/engine.aspx
cooltouch
Jul 24, 2012 09:06 PM
ef9101
Jan 30, 2009 01:48 PM
mpenner
Jun 24, 2008 05:56 PM
russell
Nov 6, 2007 10:29 AM
Firehawk989
May 14, 2007 07:13 PM
