Questions on a Radiator
Old May 21, 2008 | 09:47 AM
JakeyMan07's Avatar
Default Questions on a Radiator
Yes i just found out that my seals are bad on my radiator and i just have a couple of questions on what should i do?
1.) should i just put stop leak and see if that will fix the problem or will that mess something up because i heard that works.
2.) Or should i get a new radiator and thermostat and put it in myself i know there is a top and bottom hose and to drain all the antifreeze out but i really dont know the steps on how to do it i am just trying to get some people opinions on what i should do its a slow leak and it takes about 1 month for it all to leak out and i love working on my 2000 civic but just some things i really dont know how to do so if you could tell me the step by step instrunctions to install a radiator in a civic than i would be happy thanks alot
Old May 21, 2008 | 09:55 AM
PREKGSR's Avatar
Default RE: Questions on a Radiator
IMO get a new radiator its very easy to replace it along with new antifreeze , i got a koyo aluminun rad and i love that thing. u might wanna check the aluminum rads out of ebay they are also really good
Old May 21, 2008 | 10:07 AM
JakeyMan07's Avatar
yah but i thought they always recomend a honda radiator are those aluminum radiators suppose to do better let your engine cool better or something or what
Old May 21, 2008 | 10:16 AM
JakeyMan07's Avatar
also whenever they say to install hoses and fill up with antifreeze and than bleed your coolen what do they mean by bleeding your coolent?
Old May 21, 2008 | 10:38 AM
JakeyMan07's Avatar
also one more question is there a transmission cooiling hose on the civic radiator if so where at but i dont think there is a transmission cooling hose on a civic radiator sorry about all these questions
Old May 22, 2008 | 08:29 AM
PREKGSR's Avatar
theres no transmission cooling hose , i've been running my NON HONDA radiatior lol for almost a year now and its one of the best things i've bought for the car , after u fill it with coolant check to see if you have a bleeder valve in my case i have a jdm engine so i dont haveone , what i did was i took the rad cap off and let the car idle untill it reaches running temp , if the fluid drops then add some more , theres a DIY around here try to look for it
alanking80
Oct 21, 2013 11:09 AM
alanking80
Apr 30, 2012 03:37 PM
WILMER007
Dec 24, 2008 11:46 PM
oldguy
Mar 17, 2007 01:03 PM
Msjessica
Jan 15, 2006 04:45 PM
