d16y7 'transmission' leak
Old Jun 2, 2008 | 10:08 AM
taintedsaint's Avatar
Default d16y7 'transmission' leak
I have a auto transmission with the d16y7 motor. There is a line going into the transmission that is leaking. I'm pretty sure that its a radiator line, but i'd like someone more experienced to reassure me. The line is connected to the transmission right next to the speed sensor. Is that a coolant line? And would i just need to change a crush ring, tighten the bolt? What would be other repair options? Thank you for your help.
Old Jun 20, 2008 | 02:02 PM
Default RE: d16y7 'transmission' leak
yes, it goes to the radiator.
put a new hose clamp on it, the kind with the screw that you tighten to clamp the hose, the stock ones are pretty weak. that's probably why it's leaking.
patrykf
Mar 23, 2014 12:49 PM
Dwack1992
Apr 8, 2013 04:05 PM
Aaron A Archer
Dec 4, 2011 05:30 AM
Aaron A Archer
Dec 3, 2011 03:38 PM
mokijo2
Dec 27, 2007 12:11 AM
