'91 Civic Fuel Filter question...
Old Jul 2, 2008 | 12:19 AM
Ruester's Avatar
Default '91 Civic Fuel Filter question...
Is it possible to clean a clogged fuelfilter, or do you always have to replace it?
I bought a new fuel filter about a year ago and I recently ran the car out of gas (fuel gage crapped out) so now it's clogged again, can I clean it out?
Thanks all,
Aza[&o]
Old Jul 2, 2008 | 02:39 AM
saiguanas's Avatar
Default RE: '91 Civic Fuel Filter question...
You won't clean it effectively. Besides, you're supposed to change it every 12 months anyway. It's due. They're only $13.
Old Jul 2, 2008 | 04:16 AM
There's a pre-filter on the inlet of the pump in the tank. That should be changed too as it seems you have a lot of crud in the tank.
Old Jul 2, 2008 | 11:38 AM
Ruester's Avatar
That means I have to drop the tank though, right? - I always have to pay someone because I don't have a garage. Just street parking here.
Thanks guys,
Aza
Old Jul 2, 2008 | 12:04 PM
No, you can take the bottom cushion of the back seat out and service the pump by reaching the top of the tank thru an access panel.
Old Jul 2, 2008 | 03:41 PM
Ruester's Avatar
Really?! That's so cool! Thanks! I'll check it out.
Old Jul 16, 2008 | 10:32 PM
Ruester's Avatar
Well, I tried getting t6he back seat cushion off, but couldn't figure out how to do that. In the front part of the seat cushion, underneath it is held on by two u-shaped pins in slots that I couldn't release. Does someone know how to remove the rear seat cushion?
Old Jul 16, 2008 | 10:50 PM
Default RE: '
if it's the same as a 92-00 civic, there's a bolt behind the drivers side rear seat's seatbelt buckle. it holds another one of those U shaped brackets to the frame.
Default RE: '
once you unbolt this, you should be able to lift the back of the seat cushion up so that the 2 other U shaped pins act like a hinge. then remove the seat.
tomp
17
Oct 6, 2011 12:58 PM
kenji51590
Feb 24, 2011 05:24 PM
Hailchristian
Jun 23, 2008 12:49 AM
seriously_furious
Aug 14, 2006 08:49 PM
cdansley
Apr 22, 2006 11:52 PM
