huh??
Old Jul 16, 2008 | 07:24 PM
SilverSedan's Avatar
Default huh??
I have an idle issue, but I can't post it. I have it saved as a .txt file on my desktop in case HCF starts working again...
Old Jul 16, 2008 | 07:28 PM
Default RE: huh??
Screen capture the text and post the image link.
Old Jul 16, 2008 | 07:32 PM
Default RE: huh??
ok dumb question time...how do I screen capture? I've got the file open with notepad
Old Jul 16, 2008 | 07:45 PM
Jon Steele's Avatar
Default RE: huh??
use the print screen button the open mspaint and paste the image into mspaint
Old Jul 16, 2008 | 08:13 PM
Default RE: huh??
not working random idle issue 97 DX. sometimes idles at 2000-3000rpms, no CEL, no known cause. throttle cable and plate move freely
Old Jul 16, 2008 | 08:15 PM
Default RE: huh??
sometimes a jab at the gas pedal will solve it till the next stop, but not always (forgot to mention D16y7, manual) seems to do it when its warmed up but not when cold. cannot remove throttle senors for cleaing, they apear to be riveted on (??) not screwed/bolted on
Old Jul 16, 2008 | 08:47 PM
Default RE: huh??
Try (1) cleaning the IACV (see forum DIY), (2) bleeding the cooling system of possible trapped air, and (3) checking whether the throttle cable is adjusted too tight.
Old Jul 17, 2008 | 02:34 PM
Default RE: huh??
Throttle cable has abit of slack, so that should be ok. I'll check on bleeding the coolant and cleaning the IACV. Prob tonight/tomorrow - oddly enough the car acted totally normal today
Old Jul 19, 2008 | 11:12 AM
Default RE: huh??
ok, removed throttle body and IACV, cleaned and replaced. Topped up coolant, but could not find the bleeder bolt/screw.
Default RE: huh??
At idle, RPMS hold at about 1100, and if given a shot of gas RPMS will drop to 500rpms or so, then climb back up to 1100. Is this due to air in the coolant system?
