put a used transmission in my civic si anyone have thoughts?
Old Jul 18, 2004 | 10:27 PM
slideman99's Avatar
Default put a used transmission in my civic si anyone have thoughts?
hi
could use some advice. i've done some wrenching but never a trans
steve
Old Aug 3, 2004 | 05:59 PM
NTX's Avatar
NTX
Default RE: put a used transmission in my civic si anyone have thoughts?
If you've never done a tranny switch, it could be tough. A good idea might be to get a friend that's done it before to watch/help you...
Old Aug 3, 2004 | 06:10 PM
thats the best way if you can. if not, then get a haynes manual for your car and follow it EXACTLY. its not a horribly hard project, but you can run into a few problems. be ready to spend a little money to fix small things along the way, things you didnt even know were broken or worn, shouldnt be to bad on a 99 si though (thats the 99 in the SN right?) if you can get a friend to help with it, it will make it a lot easier. those damn trannys are hard to hold straight and line up the input shaft when reinstalling it by yourself. its possible, just not easy. Personally I say go for it. one way to learn, right? Good luck.
92vxxx
Mar 3, 2012 11:44 AM
armando.408
May 22, 2011 12:40 PM
biocpu
Oct 6, 2008 12:16 PM
SamTay
Jan 18, 2008 09:49 PM
pWnEdU
Jun 29, 2006 08:30 AM
