D16z6
Old Feb 2, 2009 | 06:53 PM
93CivicDeafGuy's Avatar
Default D16z6
Problems:
Idling up and down when cold, 500-1600 RPM
Found the post about the FITV, will do it on the weekend
Oil leak between Transmission and Engine
A tech tells me it's a rear main seal for the crankshaft, anyone out there that has a similar problem and point me the right direction?
Heater works on and off but now it doesn't
Where can I start looking for trouble shooting?
Anyone in San Diego can help me work on the engine? Free Beers of course
Old Feb 2, 2009 | 07:00 PM
In addition to cleaning the FITV, also clean the IACV and bleed the cooling system.
First carefully check the distributor, the VTEC solenoid, and the valve cover and oil pan gaskets.
Check the coolant level in both the radiator and reservoir when the engine is cool.
Old Feb 2, 2009 | 10:13 PM
Thanks for the tips Ron!
Old Feb 2, 2009 | 10:16 PM
croninc's Avatar
Its pretty normal for your car to idle high around 1.6k rpms. It should drop down to 700-800 when warm tho.
spevie
Jan 13, 2021 01:48 PM
StifflersMom
39
Jan 27, 2005 12:56 AM
fast93civic
Dec 17, 2004 03:06 PM
94si
EG Swaps
Dec 14, 2004 06:53 AM
AnakinKenobe
Nov 11, 2004 07:08 PM
