1998 hx
Old Apr 1, 2009 | 01:38 PM
ladyneedsadvice's Avatar
Default 1998 hx
Hello everybody,
I have a 98 hx and the exhaust manifold is cracked. It was welded but did not last. question is: can i just replace the manifold or do i have to replace the catyletic converter also and how much should this cost? would accept all help!!!!
Old Apr 1, 2009 | 03:46 PM
if its the one piece header/cat then you need to replace it which is 1 piece.
or if you want to switch the exhaust to a EX header and cat and mid pipe for better looks and to probably last longer
Old Apr 1, 2009 | 05:07 PM
croninc's Avatar
yes you will if you stick to the oem setup you will have to buy a new header and cat. because its 1 piece. If your not looking to upgrade I would just order a new one from an online site like http://www.hondaautomotiveparts.com/ because it will be $20-$40 cheaper than going to the dealership
Old Apr 1, 2009 | 07:25 PM
if your state is not too tough on emissions magnaflow makes the one piece header/cat combo for about $500
Old Apr 3, 2009 | 07:22 AM
Default 98 hx
Hi folks,
Thanks so much for your advice. #2 if I change to an EX mani are there any extra adapters needed?
I had the tranny rebuilt about a month ago and it was calibrated at a Honda dealer, but it surges a couple hundred RPM's during acceleration is this normal with the CVT tranny. I'm trying to get used to the in an outs of my car, I don't work on it myself but in the past have been great at knowing when things aren't right with my cars.
One more thing, how do I know if my car has cali emmissions.
Thanks
Old Apr 3, 2009 | 07:42 AM
well to swap to a EX exhaust you need a EX or aftermarket header, and a EX cat converter, also preferably the mid pipe for the exhaust for a EX as well. and if you use a stock ex header or aftermarket header without a front O2 sensor bung then you will need a short and long O2 wire extenders.
i have a long O2 extender for sale if interested check the FS forum here.
i swapped my DX exhaust for a ex exhaust setup. worked great so far other than the 5speed shifter sometimes hitting the pipes in 5th gear and reverse
and a exhaust leak around the back of the cat converter since i had to modify my dx piping and i didnt fully weld it yet.
froggy780
Apr 30, 2011 09:23 PM
Tornado_sp1
Jul 20, 2004 10:10 PM
Grolschkid
Jun 21, 2004 05:04 PM
froggy780
May 27, 2004 07:27 PM
froggy780
May 19, 2004 08:46 PM
