95 honda ex turbo
Old Apr 3, 2009 | 07:24 AM
dougybadboy's Avatar
Default 95 honda ex turbo
Anyone on here can tell me where or who can reprogram my stock computer. I just put together a d15b with 50mm turbo I have installed 4 bar map and wide band 02 sensor car is running real rich.
Is there a performance chip I can buy or do I need to break down and buy a after market unit.I'm new to the ricer game allways had big blocks.But all ways wanted to build a bad *** 4 banger. I just wish I could work out the bugs and go bust some big block ***.Thanks for any info Doug
Old Apr 3, 2009 | 07:49 AM
croninc's Avatar
http://www.phearable.net/
check them out, you can order a chip ecu that you can then get tuned. I recommend Hondata if you can afford it, or chrome.
Old Apr 3, 2009 | 08:01 AM
thanks cronic I will check them out.thanks again Doug
Old Apr 4, 2009 | 08:04 AM
bcrichguitars's Avatar
I have a chipped P06 ecu ready to go. It was tuned at 9psi on a 14b turbo on a d15b. Should work fine as a basemap until you can bring it to a tuner and have him burn you a new tune.
Let me know
It would be $68.40 CAD including shipping. Its about $55.50 USD.
Old Apr 5, 2009 | 08:08 AM
All basemaps that come from Phearable are Crome unless you specificy you want something different, which i don't even know what options they give you. But you do need an OBD1 ECU with a chip and a professional tune. Don't drive that without a tune.
Old Apr 6, 2009 | 07:38 AM
DO NOT GET A TURBO BASEMAP FROM PHEARABLE! I ordered one and I regret it. After my engine was done in the machine shop and everything was back in the car, I started the car using my "basemap" ECU from phearable. The car idled at 3000rpm (I thought it was a vacuum leak), the tune was dangerously rich (Blowing black smoke smelling like gas), and I only got it about half way home on that basemap before I had to call a tow truck as I couldn't go over 20km/h and I didn't want to risk damaging the engine. I had it towed to a local import shop and they checked everything and said it has to be the ECU. So I put my old ECU back in which was the P06 and it ran normal and in safe AF Ratios to drive it to my tuner to have the phearable P28 tuned right.
I'm going to guess my P06 would be a better basemap to get you home/to the tuner than any phearable ecu. Maybe you could trust phearable for a N/A ECU, but not forced induction!
Old Apr 6, 2009 | 08:39 AM
^ i was in a similar situation. Before i ordered from Phearable i heard great things, but once i got my ECU and basemap and brought it to the tuner, he was asked "You didn't boost on this map did you?". He said it was so lean he didn't know what they were thinking. Prices are pretty good though, and i HAVE heard of the basemaps being almost perfect, but i guess in the end don't drive on a basemap, just get it tuned.
cody_m11
Apr 22, 2008 04:31 PM
eg9
May 22, 2006 04:43 PM
forrealb50
Mar 29, 2006 07:57 AM
TrailorParkPimp
Aug 28, 2004 12:21 PM
