catback
Old May 3, 2009 | 03:09 PM
kasey_320's Avatar
Default catback
got a 95 civic cx. would a 2/4 door honda civic cat back exhaust system fit? would it require cutting?
Old May 3, 2009 | 04:20 PM
will not fit.
requires some shortening before the S-bend, and then some shortening the piping directly before the muffler. After that though, it'll fit great.
credibility of this statement: I had to do the same thing on my del Sol, which has extremely similar exhaust routing as (and rumored to be identical to) the 92-95 hatchback.
I recommending taking it to a small-business exhaust shop and having them do it. It's much easier to figure out how much to shorten everything when the car is up on a lift. It cost me around $80 total to get it all trimmed to fit.
Old May 3, 2009 | 05:24 PM
kasey_320's Avatar
reason im wonderin is cuz my car smokes cuz the cat is stocked up. so i figured buying a new catback would help but dont wanna spend alot so advancedjdmparts is wher i looked and out of stock for hb. so im jus gonna order a muffler and have the shop in town cut the cat out n run piping for a fake cat.
Old May 3, 2009 | 05:32 PM
If the cat is clogged then replacing the catback isn't going to do jack ****.
Replace the catalytic converter.
Is your catalytic converter under the car or is it right in front of the engine?
Old May 4, 2009 | 03:45 AM
kasey_320's Avatar
under
Old May 4, 2009 | 06:42 AM
Bad cat will not make the car smoke. Is it oil smoke (blue/gray) or fuel smoke (black)? In the first case the engine is worn out. In the second one there is a control problem making it run rich.
Running rich can burn out the cat, but it's not the other way around.
Old May 4, 2009 | 11:52 AM
kasey_320's Avatar
black smoke. i was told it was from the cat bein stocked up.
Old May 4, 2009 | 12:26 PM
The black smoke comes first, then the cat gets stopped up because of overheating. Black smoke also means that you're wasting gas like crazy.
Is your car all stock, or is it modified? Is the check engine light on?
Old May 5, 2009 | 05:51 PM
kasey_320's Avatar
all stock. no check engine light.
ive been running that shell nitrogen enriched gas. someone said it could be the clean gas (shell) cleaning out the old gas from the cat. could this be y it smokes?
bayar1987
Apr 19, 2007 10:41 AM
Em1_ProJect
Mar 24, 2005 05:50 PM
klamslam
Feb 10, 2005 08:03 PM
02CivicEX
Feb 3, 2005 07:04 PM
FizzGiGG
Jun 1, 2004 12:46 PM
