Any tips for removing this difficult fuel filter?
Old May 20, 2009 | 04:30 PM
inthezoneac's Avatar
Default fuel filter leaking from bottom nut!
ok thanks, got it off
however, i put on the new filter and the bottom nut area leaks. Try old filter, still leaks. No washer goes on the bottom area, but that's where it's leaking.
Old May 20, 2009 | 05:06 PM
There's a simple trick. I think there's a 19mm nut at the base of the filter. Use a 19mm wrench and 14mm wrench in a scissor-like configuration to break the 14mm nut loose with a squeezing action.
Old May 20, 2009 | 05:58 PM
Old May 20, 2009 | 06:02 PM
The nut is probably not quite tight enough. Use the scissor-like action again but with the wrenches reversed to get the nut tighter.
Old May 20, 2009 | 06:51 PM
I'll mess with it again tomorrow, I tightened it a little more where it's about 99% leak free lol
I hate working on my car and then some bs happens, makes me want to never work on it again.
Old May 22, 2009 | 09:01 AM
RAVIE's Avatar
try a new washer fyi on the bottom of the filter there is two washer if i can remember one washer goes on the nut you insert it in the line and then another washer goes after then you screw it on the filter
tomp
Apr 12, 2011 11:42 AM
black95coupe
Jan 28, 2010 04:53 AM
Hailchristian
Jun 23, 2008 12:49 AM
pusha1031
Nov 6, 2007 07:41 PM
seriously_furious
Aug 14, 2006 08:49 PM
