Engine will crank but wont run (electrical)
Old May 26, 2009 | 10:58 AM
pjku79's Avatar
Default Engine will crank but wont run (electrical)
OK, I have a B18 swap in my car (bought it this way) and had a fuse blow for my headlights over the weekend. It took me a while to figure out it was the fuse, so I was looking at wiring connections trying to trace it down. After replacing the fuse I went to go drive it today and it will crank and start, but wont run unless I move the throttle to keep it running. It ran fine with the fuse blown before, so I assume these are two totally separate issues. My assumption is while I was searching for the light issue I must of knocked a wire lose or something. Can you give me some things to look at? I can hear the fuel pump turn on when I key the car on. Keep in mind this was an engine swap, so the wiring is a mess and I was fooling with wires around the engine controller. Thanks for you help.
Old May 26, 2009 | 11:16 AM
If you can keep it running at approximately normal idle speed by pressing lightly on the gas, check the idle air control valve or its wiring.
Old May 26, 2009 | 12:46 PM
pjku79's Avatar
OK I looking in to the IAC Valve and found there should be a yellow/blk and blue/blk wire. I saw you could check the yellow/blk wire with a ground to see if it has 12v when the car is on, which mine does. But, I couldn't find any where that would tell me how to check the blue/blk wire. I thought maybe if I plugged the connector in while the ignition was on I would hear the switch activate, but either that didn't work or it didn't switch.
Old May 26, 2009 | 01:54 PM
pjku79's Avatar
ok the iac valve wiring was open. i found a loose wire. thanks.
Salim
Jul 8, 2015 10:53 AM
zerojett
Oct 18, 2011 03:01 PM
mike95691
Nov 24, 2007 05:29 AM
samilitant
Jan 8, 2007 10:47 PM
Remmy
Mar 6, 2005 01:18 PM
