help installing rear 6x9 in 98' hx
Old May 29, 2009 | 06:49 AM
bmac9269's Avatar
Default help installing rear 6x9 in 98' hx
i have alpine type s 6x9 and installed them in my 98 civic hx coupe and was wondering if there is any better way to put them in other than taking off the stock speaker covers, how can i get the rear deck off easily? thanks
Old May 29, 2009 | 07:06 AM
gunz4me's Avatar
You won't get the rear deck off easily. you get to remove the bottom half of the rear seat and the side plastic panels before you can slide the deck out of there.
I highly recommend you mount your 6x9s from underneath the deck to make it easier to swap them out at a later point in time.
ETA - Here you go: https://www.hondacivicforum.com/foru...ad.php?t=18391
Old May 29, 2009 | 08:04 AM
dito.... no easy way about it unless you mounted the speakers from the bottom last time. i hate the rear deck! i gotta pull mine eventually and bolt it in since it rattles like a ****!
Old May 29, 2009 | 01:34 PM
enigma34's Avatar
yup, fun fun
Old May 29, 2009 | 02:40 PM
gunz4me's Avatar
You too? All I have is ONE 8" sub and it pounds enough to make my rear deck plastic smack the back window. I am thinking of bolting it in there and using some heavy duty Velcro.
Old May 29, 2009 | 03:00 PM
ya the way im going to do mine is clean the plastic and then with some liquid epoxy im going to glue in some nuts, then when i slide the deck inplace i can bolt it TIGHT from the bottom. no more weak @ss clips holding it in!
new_2_civics
Apr 10, 2014 12:40 PM
bmac9269
Aug 8, 2009 08:59 PM
00IntegraLS
Oct 24, 2007 01:48 AM
redbawks
Sep 14, 2007 08:10 PM
FishV12
Nov 8, 2006 08:49 AM
