Ignition Switch difficutly
Old May 31, 2009 | 08:55 AM
n8izzle's Avatar
Default Ignition Switch difficutly
Hello, I need your help.. My girlfriend has a 2000 EX Honda Civic.. and when she tries to put her key in the ignition some times the key can not turn start they engine... In order for her to start the car she has to play with it a bit.. I am sure that its just the ignition switch but i dont know if this is a common problem.. If anybody knows a quick solution rather than replacing the switch your help would be greatly appreciated.. If not, do you know if there is any other year of civic compatible for the switch that i can pull off a junk yard? thanks for your help in advance..
Old May 31, 2009 | 10:45 AM
You might want to try lubricating the lock with a graphite-based powder specifically used for locks. I think it can even be purchased from Walmart.
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
dartax
May 29, 2010 08:22 PM
bceja10
Oct 4, 2006 02:14 AM
b3651
Sep 24, 2005 09:46 PM
aredecomm
Jun 6, 2005 03:11 PM
