breather filter ???
Old Jun 28, 2009 | 05:24 PM
EM24ever's Avatar
Banned
Default breather filter ???
would putting a breather filter on my valve cover be a bad idea im hearing different stories .
Old Jun 28, 2009 | 05:27 PM
It'll be fine.
Old Jun 30, 2009 | 11:18 AM
EM24ever's Avatar
Banned
i decided against it seeing how the pcv on a EM2 needs vacuum from the intake to function properly .
Old Jun 30, 2009 | 01:06 PM
Big Mick's Avatar
I have one on the vale cover of my 2000 civic just fine.
Old Jun 30, 2009 | 01:17 PM
hamorhead's Avatar
what does it even do?
Old Jun 30, 2009 | 01:43 PM
EM24ever's Avatar
Banned
it vent gases caused by heated oil and blow by gases in the crank case . the tube coming out of your valve cover that connects to the sri . it really needs the vacuum from the intake to function properly .
Old Jun 30, 2009 | 03:42 PM
hamorhead's Avatar
so then the breather filter isn't any good cuz it needs vacuum?
or does none of this really matter and the filter is more like engine bling?
Old Jul 1, 2009 | 08:44 PM
conceptualpolymer's Avatar
Pretty much all cars, trucks and busses use a "closed system" in that blowby gasses containing oil, water, and some unburned fuel are expelled from the crankcase and reburned by the engine. Diesel buses and some trucks use large oil/air separators to remove oil and particulates before they get pulled into engine and escape (to some extent) out into the atmosphere. If you vent these gases into your engine bay via the filter, some of that oil and unburned fuel will coat your engine over time. What's worse is that it also gets out into the atmosphere, contributing to pollution.
Generally speaking, small engines produce far less blowby contaminants than do 6 and 8 cylinder engines, so catch cans (to trap some of the oil and water) are not really necessary.
Skip the breather filter and get something that'll really help.
Old Jul 2, 2009 | 05:27 AM
hamorhead's Avatar
thanks for explaining
MaximusFunk
Nov 22, 2009 03:16 PM
JJ Zettle
Mar 29, 2007 03:56 AM
tombakers
Feb 5, 2007 11:19 AM
TrAvMaNFTW
Apr 18, 2006 12:38 PM
civic1.5uk
Aug 5, 2004 03:54 PM
