B18 Swap question
Old Aug 4, 2009 | 07:25 PM
radeon55's Avatar
Default B18 Swap question
Ok, I have read around and can't find out a straight answer about which tranny to use in the swap. I have a 99 civic ex. Can I use my tranny that is in the car or do I need to get a different one. Also, can someone give me a complete list of everything I would need to do the swap. Everything I have read all say different on what all is needed. I want to make sure I don't forget anything if I do the swap.
Thanks in advance.
Old Aug 4, 2009 | 08:11 PM
Tiran's Avatar
Chances are no.
If you car is stock then you have a D series engine.The B18 is a B series engine (hence the B) and requires a B series transmission. As yours is a D series transmission, it will not work.
You will need a b-series transmission. Anything from a B16, B18, or B20 will work.
Also which B18 do you have?
Old Aug 4, 2009 | 08:49 PM
you will need for "b series
complete motor (im,em,dizzy,starter,wire harness)
trans
cv axles
rotors and brakes
aftermarket motor mount(hasport makes good ones)
ecu
if i can think of what else 'll let you know
Old Aug 4, 2009 | 09:34 PM
xsteinbachx's Avatar
trans
cv axles
rotors and brakes
ecu
He doesn't need aftermarket motor mounts.. he could use OEM ones...
Old Aug 5, 2009 | 06:40 AM
plethoric33's Avatar
Have you decided what B motor your going with yet? I would actually try and find what people have said about them after swaps instead of just jumping into the usual B16 swap. Plus decide whether your going to boost later or stay NA.
I never heard that I needed brakes and rotors for a B series car either and I have a swapped car haha. Is that correct?
Old Aug 5, 2009 | 08:56 AM
a B" tranny has different splines on the cv axles than a D' tranny
idk about your gen but i've done a few swaps and had to do this
Old Aug 5, 2009 | 10:55 AM
When I said OEM motor mounts.. I meant OEM B Series if he was doing a B series swap.....
mike1990civic
ED-EF Swaps
Dec 13, 2005 10:06 PM
honda4life
Aug 27, 2005 08:13 PM
stang
EK Swaps
Aug 22, 2005 12:24 AM
grncivicvtec
Mar 18, 2005 08:23 PM
grncivicvtec
Feb 25, 2005 01:12 PM
