condensor fan not turning on
Old Aug 12, 2009 | 08:54 AM
jamesdal1's Avatar
Default condensor fan not turning on
OK, I have a 2000 Honda Civic, 4 door. I can not get the AC condensor fan to turn on. I hear the compressor turn on, it blows COLD air on the highway, when at stop or slow traffic, air is not cold. I checked the fuses and all are good. How can i over ride and force the fan to start? I can move the propeller, but when i turn on the AC, fan will not turn on.
Last edited by jamesdal1; Aug 12, 2009 at 09:14 AM. Reason: not complete statement.
Old Aug 12, 2009 | 09:44 AM
Check the ground wire on the condenser. Then check if power is reaching the fan, probe the fan plug while still plugged in. If the fan has power but doesn't run, motor is bad. If the fan doesn't get power but the ground is OK, probably the relay. Swap it with one of the other relays of the same type on the car.
Old Aug 12, 2009 | 10:04 AM
jamesdal1's Avatar
how can i check if power is getting to the motor? can i take the relay from the coolant fan and put in the condensor fan relay?
Old Jun 19, 2011 | 09:36 AM
jamesdal1's Avatar
OK, i forgot to update this, it ended up being the ac condenser fan. even though it would turn on, it was working properly. I replaced the ac condenser fan and now works like a charm. Here is what the motor would do:
YouTube - ‪2000 Honda civic condenser fan‬‏
Rabbi
Dec 3, 2011 08:39 AM
Infinitrium
May 4, 2011 12:13 PM
bigmikew1
41
Mar 15, 2010 09:33 AM
addiction2bass
Aug 22, 2008 03:32 PM
madmurray
May 1, 2008 02:21 PM
