Appears to be a dead battery but...
Old Aug 17, 2009 | 10:19 AM
jbum's Avatar
Default Appears to be a dead battery but...
Hi,
I would have searched the forums more but I'm on my phone away from a computer. My friend's car is dead. First thought it was the battery.
When you set the key to position 2 right before the ignition fires usually all the dash lights light up. However the lights now click and blinks for a littlw while and fades. When u try to start the car all the lights go away and there is no sound at all.
We tried jumping the car but the rescue car won't start with the cables connected. It's as if there is a drain being caused by the bad car. I confirmed it by starting the rescue car with the cables and it's fine.
You guys have any ides???
Old Aug 17, 2009 | 10:58 AM
jbum's Avatar
ok... i feel dumb now. finally called AAA and the guy's battery boost unit was able to start the car.
i guess my '93 civic (the rescue car) battery is either not strong enough or about to go. i wasn't able to even start it to begin the battery jump. very strange as I've never experienced that before. usually the 'good' car starts fine without a hitch.
anyways, i think we can delete this thread. thanks.
Old Aug 18, 2009 | 03:25 AM
Bad connections at the battery can make it seem like a dead battery. The connections on your battery may be loose, when you connected the jumper cables the connection got bumped then your car wouldn't start.
Old Aug 18, 2009 | 09:27 AM
jbum's Avatar
thanks for the reply. i took it to kragen's and got the old battery checked just to verify it was dead. it was reading 9v. we tried resuscitating it but 9v is pretty dead and as expected the charging didn't work.
it was genuine honda battery from a 2006 civic... i know batteries don't last forever but it's the shortest life for a battery i've experienced ever.
oh well... you live long enough, you see everything there is.
EBorsini
Mar 1, 2015 10:00 AM
mobog
Mar 7, 2009 07:12 PM
AnimalWild
Jun 27, 2008 11:46 AM
VinceDee
Jun 21, 2007 04:09 AM
