Putting Power Steering In A DX?????
Old Aug 23, 2009 | 09:14 PM
WTFJayJay's Avatar
Default Putting Power Steering In A DX?????
so the dx is pretty basic as far as everything goes. roll up windows no power steering and all.
welll..... how hard would it be to put power steering in? i know it can be done, but just dont know if its worth the money. im sure i could do it myself, but im thinking it would prolly be cheaper to find a totalled civic (model that has power steering) and just rip everything out.. assuming they are in the same few years that parts would still fit.
so just want some input on the idea. and does anyone know that this has ever been done and if so in there a write up for it?
thanks..
Old Aug 23, 2009 | 09:17 PM
Well, you need the power steering pump, the belt, maybe a pulley... I forget. I'm sure trustdestruction will jump in and help... I think you may also need the whole steering rack.
Old Aug 23, 2009 | 09:18 PM
ive done this
all you need is
power steering rack n pinion
and all lines
fluid canister
pump
pump bracket
fluid
and belt.
and the harmonic pulley
dx has only 2 belt slots
ex has 3 belt slots
Old Aug 24, 2009 | 06:43 AM
Yeah if you can find a parts car to strip, it's very feasible, everything will simply bolt on. You will need to have the wheels aligned after replacing the rack.
Buying all the parts new is quite expensive.
Old Aug 24, 2009 | 07:17 AM
Justin13's Avatar
Banned
My DX has power steering...
Old Sep 23, 2009 | 06:52 PM
TxFireman1972's Avatar
Glad I found this post. Been wanting to add power steering to my daughters car too. Anyone have any power steering stuff for a 95 Civic laying around?
Old Sep 24, 2009 | 01:40 PM
If found a bunch of power steering parts on EBAY, but alot of them are for the D16Z6 SOHC VTEC 1.6L but I have the D15b7. Will they work on either motor or are they different?
Old Sep 24, 2009 | 02:00 PM
Are the lines, brackets, and reserviors the same for any of the engines?
Old Sep 25, 2009 | 09:18 AM
The only parts that attach to the engine itself are the crank pulley and the bracket. And I think those are the same. Everything else doesn't matter which engine you have, it needs to match the body of the car. So make sure it's for a 1992 to 1995 model. The Si may be different but any EX or LX rack will certainly fit your DX.
Use only Honda power steering fluid or something marked specifically as suitable for Honda. Generic "for most major brands" fluid will ruin the seals.
Old Sep 25, 2009 | 09:28 AM
if your car is a 92-95 civic than any 92-95 civic/del sol with power steering will fit. i put a power steering from a 94 hatch into my 95 sedan.
just need the parts i mentioned above.
