confusing problem!! car wont move
Old Sep 2, 2009 | 12:07 AM
roman01112's Avatar
Question confusing problem!! car wont move
hey guys.first of all.thxxx for all the help you guys might give me with this question.
my car will not drive.i just replaced the clutch bearing,clutch,flywheel,and the throwout bearing.and the tranny was replaced about 1k miles ago.my car starts perfectly fine.no knocking,chattering or any of that. it goes into gear. but just does not actually transfer power to the wheels.any help??? would be greatly appreciated.by the way car only has 90k miles on it.i also been searching the forums for a while.and havnt been able to find anything related. and yes i used the search link also.
Old Sep 2, 2009 | 04:50 AM
get under it and make sure your cv axle are all the way in the trans. make sure there is NO gap.
Old Sep 3, 2009 | 01:23 AM
roman01112's Avatar
Alright ill check.if there is a gap. I have to just hammer the cv axle in more right? Then tighten the axle bolt with a pressure gun? Thanks for the help
Old Sep 3, 2009 | 03:03 AM
just wiggle and tap it in more into the trans... the axle nut should already be tight...
Old Sep 3, 2009 | 04:36 AM
kanarrjl's Avatar
any noises?
Old Sep 3, 2009 | 07:12 PM
roman01112's Avatar
no.when i rev it there isnt any irregular noises or anything like that
Old Sep 4, 2009 | 05:09 AM
did you check the cv axles??????????
Old Sep 4, 2009 | 10:49 AM
PunisherInOKC's Avatar
+1 on 94civic's post.
Either its your CV's, or the clutch was installed incorrectly, and has broken.
Old Sep 17, 2009 | 09:39 PM
roman01112's Avatar
yeah i checked all the stuff and my clutch forks broke.
hella bs,well thxx anyways guys
Steve Salonek
Apr 11, 2013 03:13 PM
Djaccent
Oct 22, 2012 02:53 PM
lcn584
Jul 10, 2010 06:58 PM
Imari007
Oct 5, 2006 12:05 AM
93EXCivac
EG Swaps
Jan 21, 2006 04:30 AM
