using a 90 ls trans on 98 gsr motor????
Old Sep 29, 2009 | 12:28 AM
hydro_yang's Avatar
Question using a 90 ls trans on 98 gsr motor????
could i use a 90 integra trans (cable) on a 98 gsr motor w/o having to change out the flywheel... and do i really need a pilot baring cause for some reason if the 98 gsr flywheel is in the 90 ls trans will not work... it is going in to a 90 civic hatch so i have to use cable... is the input shaft on tha 90 trans different in size compared to the orginal gsr trans help me out guys... need to get the damn car done soon
thanks
hydro
Old Sep 29, 2009 | 12:39 AM
ef9101's Avatar
u can use the hydro trans just get the conversion bracket hasport.com lil priced but hydro is better but fornow u chould stick with cable but srry no u have to use the flywheel for the original 90 ls trans
Old Sep 29, 2009 | 02:23 AM
no you will need the 90 tegra flywheel and also you need the pilot bearing.
Old Sep 29, 2009 | 08:58 AM
hydro_yang's Avatar
thanks guys
Mike Diaz
Dec 9, 2007 02:41 PM
sleepin stock
Oct 4, 2007 06:43 PM
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
