Transmission Bearing Noise?
Old Oct 6, 2009 | 06:41 PM
ether.real's Avatar
Default Transmission Bearing Noise?
Hello all, looking for advice on my 1996 Civic DX hatchback. It has a 5 speed manual transmission, with 152k miles.
I am concerned about what sounds like a bearing, here are the symptoms:
-grinds when the car is in neutral, with the clutch out. Goes away when I press the clutch in.
-I cant hear it when the car is moving.
-worse when its cold, and at first start. Quiets down if the car is warmed up for a while.
-Everything shifts fine.
I have heard that this can be due to the throwout bearing, however this bearing got replaced when I had the clutch replaced, and the sound did not go away. Another suggestion is the Input Shaft Bearing.
I realize that I might as well replace the tranny instead of the bearing, however, what I am curious about is, what happens if I keep driving on it? Does it slowly get worse until it breaks, or does it carry a risk of catastrophic damage?
Thanks in advance,
ether
Old Oct 6, 2009 | 06:46 PM
have you checked the fluids in it?
eventually it will start jumping out of gear,(syncronizers go bad)
gear by gear.
Old Oct 6, 2009 | 08:23 PM
ether.real's Avatar
Fluids are fine, it got flushed when the clutch got replaced last year, and has been checked every few months.
Old Oct 6, 2009 | 08:50 PM
jprommel's Avatar
Angry Admin
Those are the symptoms of your input shaft bearing slowly going bad; throwout bearing is when you push the clutch in you hear the noise.
Old Oct 7, 2009 | 05:45 AM
BX_Civic's Avatar
Yo ether are you formally from EOCF? Im BigO from over there....
Old Oct 7, 2009 | 06:50 PM
ether.real's Avatar
Yep, from EOCF, now at NBOC. Own two Civics that are getting older these days, and always looking for good resources for maintenance/repair....
BoostedAWD91
Sep 10, 2011 07:30 PM
droopy128
Feb 29, 2008 11:11 PM
digimon916
Jan 13, 2008 10:52 AM
TITIKO
Jan 10, 2005 10:23 PM
