View Poll Results: Have you ever replaced the clutch in your car yourself?
Yes, recemtly.
0%
Yes as an assistant.
0%
No, but I am going to when it needs to be done.
100.00%
No, I have someone else do those things.
0%
Voters: 2. You may not vote on this poll
Clutch R&R '90 CVIC DX
Old Oct 9, 2009 | 07:36 PM
Li'l Red's Avatar
Default Clutch R&R '90 CVIC DX
My new toy a 1990 Honda Civic DX Manual has abot 153K miles. I don't know if the clutch has ever been replaced before. It slips sometimes as I apply the clutch disc going from First to second and very occasionally from 2nd to 3rd. It's doesn't feel like it's urgent, just inevitable. I figure the years on the car plus the difference in my driving style hastens the failure.
So, I am pretty good mechanic and have pulled motors and a transmissions before, but I can't afford to screw this up.
I imagine the parts would be under $100 and I have all the tools so I think I can do it successfully.
Can someone give me an idea of the difficulty of this job?
Old Oct 9, 2009 | 07:53 PM
ive posted this info up before for someone, its not hard, just remove cv axles, put jack und trans, unbolt everything form trans, even shift linkages(one from trans other from shifter) then unbolt the bolts around the trans housing and then lower jack and wiggle trans off, you may have to pry it a little, but you should be able to drop it in less than 2hrs since this is your first time, the main part is when you install the new clutch use the alignment tool to get the clutch disc straight before tightning the pressure plate bolts. if you have anymore ????? about something post a pic and ill give you details
rcvicdude
Nov 1, 2009 12:55 PM
bigolsackapoo
Sep 4, 2008 04:50 PM
the727kid
Apr 21, 2006 12:00 PM
the727kid
Apr 15, 2006 02:58 PM
the727kid
Apr 14, 2006 03:51 PM
