Intrument Cluster help
Old Oct 14, 2009 | 12:09 PM
1995CivicEXBMF's Avatar
Default Intrument Cluster help
Ok I started a project to insert Speed Glow to my Cluster. I spliced into two wires one power one ground. However now my RPM need does not work at all and the Speed Glow lights only work when the Headlights are on and the Engine is off. Once I turn on the car and power up the Engine the Speed Glow lights turn off and the RPM needle doesnt budge. I know power runs into the wires I spliced but I need to know how to fix the problem so power is returned to the wires when the Engine is on.
I have already disconnected the Speed Glow from the wires I spleced but power is still not being directed through when the Engine is on.
Old Oct 14, 2009 | 12:30 PM
supersize's Avatar
Sir Banned-a-lot
make sure the wires are properly connected. use a cap if you have to.
Old Oct 14, 2009 | 12:48 PM
The wires look like they are all connected right just for some reason no power goes to them when i turn the car all the way on
Old Oct 14, 2009 | 01:26 PM
DaOne's Avatar
Maybe they need more electricity? o.O
Old Oct 14, 2009 | 01:28 PM
supersize's Avatar
Sir Banned-a-lot
check to see if the wires themself are gettin powers, you got a voltmeter?
Old Oct 14, 2009 | 01:45 PM
No i dont have a voltmeter ive tested the wires with a speed glow part and there is current because the light on the speed glow turn on when the key is in the on position then turns off when i start the car. Also i made a discovery that i may have tapped into my alarm because the doors locked and unlucked when i tested the current
Old Oct 14, 2009 | 01:54 PM
supersize's Avatar
Sir Banned-a-lot
that aint good lol, i dont know how to help you with this, im rly new to cars.
Old Oct 14, 2009 | 02:09 PM
Its ok man i look at it this way try something and fail then try something else, I just wanted to see if i could get some help so i didnt have to go and buy new wires if i didnt have too
Old Oct 14, 2009 | 02:24 PM
Clearly you're using the wrong wires. Disconnect all your mods and get the car working again stock. Then come back and try again.
If it's a 1995 I have a diagram and could help you with the redo.
There are lots of wires that seem to be "power" and "ground" but they are actually used for something else.
Old Oct 14, 2009 | 02:45 PM
Everything is now disconnected and its just the stock wires now im looking at a haynes manual to search for a possible problem
