Need your opinion on a transmission issue
Old Nov 19, 2009 | 03:39 PM
izotop's Avatar
Default Need your opinion on a transmission issue
Ok,
Civic 2004 Coupe, M5. 92000km or 57000Mi
I'm gonna tell you the main points of the story..
1 month ago, when I bought my car, I immediately noticed a problem with the reverse on my transmission. Often, it did not get into gear and the gears would just grind one against the other without any motion.
So the dealership took my car back for 3 weeks. They tried all sorts of thing. In the end, even though it isn't clear what they did, I got it back and it was in a better condition.
I've been told three things: One told me the transmission was brand new, someone else told me that MY transmission had been rebuilt (some new bearings, synchros, gears, casing...), and someone else told me that I had got a rebuilt transmission directly from Honda Canada.
What I really want to know is, is it normal that the reverse would sometimes "block" before entering into gear? Because even though it happens less often than it used to, I still get that problems 20% of the time. Then, I have to release the clutch, maybe put it in first, and then it enters. It's totally arbitrary as to when it happens.
I'm ready to argue with the dealership, but first, I want to know if I'm fighting for a real issue. My previous car, which was a Saturn with 110000Mi on it, never did that. Today, I talked to the chief executive officer and I feel like it's not going to be an easy fight.
Plus I have that freaky Check Engine light that doesn't want to come off.
Here are my options.
A) I get reimbursed and I run away with my money.
B) I have a meeting with the CEO and a technician to see what are the "mechanical" options
But before I take a decision, I want to know the opinion of you, long time civic owners that have seen a lot I guess!
-Desperate guy
Old Nov 23, 2009 | 01:07 AM
croninc's Avatar
well in 6th gen civics, yours is a 7th gen, this is a normal problem. Happens to me a lot, isnt really a big deal.
Anyways you should get that CEL checked out, take it to an auto parts store and ask them to pull the code(s). Then you will know the problem. Once you get that code we will be able to help you.
mudhenFUF
Jan 16, 2023 08:43 PM
MattGeetar
Jan 12, 2012 08:41 PM
Forty04
May 24, 2005 09:02 PM
