B16 SIR 1 OR B16 SIR 2
Old Jul 31, 2004 | 12:11 PM
outlawzz23's Avatar
Default B16 SIR 1 OR B16 SIR 2
I JUST WANT TO KNOW IF ITS EVEN WORTH BUYING A SIR 1 MOTOR OR SHOULD I JUST SAVE MY MONEY AND BUY SIR 2 MOTOR. THE SECOND GEN B16 HAS 10 MORE HP BUT IT IS WORTH ATLEAST $700 MORE THAN THE FIRST. I JUST WANT UR OPINIONS ON WHAT I SHOULD DO. AND IF ANY BODY HAS ANY WEBSITES OR PERFORMANCE SHOP WHERE THEY HAVE GOOD PRICES COULD SOMEBODY HOOK A BROTHER UP.
Old Jul 31, 2004 | 06:04 PM
Default RE: B16 SIR 1 OR B16 SIR 2
it all depends on what kind and year your car is. also, where do you live? in cali, smog legality is an issue.
Old Aug 1, 2004 | 11:38 AM
outlawzz23's Avatar
I GOT A 93 HATCHBACK I LIVE IN JERSEY. I HEARD THAT IF I GET A Ist GEN B16 IAM GOIG TO NEED A DIFFERENT WIRE HARNESS.
Old Aug 2, 2004 | 12:16 AM
yeah, you'll need the wiring adapter, and its pretty pricey, youll also need a mount kit, and either a conversion kit for a cable clutch, or a hydrolic tranny. just go with the higher compression of the b16a2(SiRII) that will basically bolt into your car with factory honda/acura shift linkage and motor mounts. you can give Hasport a call @ 602.470.0065 , they were very helpful to me when i was doing my swap, even though i didnt end up buying anything from them.
Old Aug 9, 2004 | 08:21 AM
2000Si's Avatar
The SiR II isn't a B16a2, those ONLY came in 99-00 USDM Si and Canadian SiRs. Let me think about this for a second...
93 hatchbacks came with either a D15b7 (DX/LX), D15b8 (CX), D15z1 (VX), or a D16z6 (EX/Si) and all are OBD I. The easiest possible swap for you would to be to throw in a B16a SiR II as it is also OBD I.
170 hp > 70, 92, 102, 125 hp... yes sir.
thatguywithahonda
Jul 3, 2013 07:36 AM
turbo speeder
Jan 28, 2009 03:57 PM
cwd14
EG Swaps
May 4, 2006 02:55 PM
farfrumugen
EG Swaps
Aug 16, 2005 11:27 PM
Roentgen
Jun 16, 2004 01:14 AM
