Help with vtec wiring
Old Mar 25, 2010 | 04:52 PM
THE_FATTIE's Avatar
Default Help with vtec wiring
I have a 95 DX that I swapped a D16Z6 into... I have the ecm from the Vtec car as well... My body harness did not have the wires ran for me to be able to activate vtec... I know I have to run 2 wires... 1 for the oil pressure switch and one for the vtec solenoid... My question is What wires do I tap into on the engine harness and where to I attach them to on the ecm... Also any good places to route the wires would be appreciated... and What type of connectors do I need to attach the wires to the ecm?
Old Mar 25, 2010 | 05:29 PM
https://www.hondacivicforum.com/foru...ad.php?t=73241
you will need 2 ecu pins to add to your ecu harness, and some wire and tape.
here is pics of when i did it.
my 2 wires i added to the ecu,
the black wire coming off the vtec oil pressure sensor gets grounded
only need pin a4 and pin d6 for sohc vtec hook up
Old Mar 25, 2010 | 05:50 PM
THE_FATTIE's Avatar
Thank you.... Just to be clear tho... I ground the black wire coming off the oil pressure switch (the green plug right?)... and then I take the other wire off the green plug and tap it into d6... with an ecm pin (where do I get ecm pins) Then the wire in the grey plug gets tapped and goes with an ecm pin to a4.... Is that all correct?
Old Mar 25, 2010 | 06:07 PM
you can goto a junk yard and yank them out of other civics or send me 2$ via paypal and ill mail you some,
the grey single wire plug goes (vtec solnoid) goes to a4 and the oil pressure wire goes to d6 and the black wire gets grounded.
Old Mar 25, 2010 | 06:37 PM
THE_FATTIE's Avatar
Whats your paypal info? PM it to me if you dont want everyone to know... Ill reply with my name and address
Old Mar 25, 2010 | 06:46 PM
everyone pretty much knows lol, i do alot of buisness here, untouchednalive2@yahoo.com is my paypal acct, ill mail it out to you tmw through postal mail
Old Mar 25, 2010 | 06:55 PM
THE_FATTIE's Avatar
Money sent... Let me know for sure you got it
Old Mar 25, 2010 | 07:57 PM
recieved, ill ship to the address on ur paypal acct ok?
Old Mar 26, 2010 | 12:34 PM
THE_FATTIE's Avatar
They should both be the same... So yeah... lol... I did not know that it showed you...
trcook
May 26, 2012 08:42 AM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
trustdestruction
Jan 29, 2009 12:02 PM
RudysImports
Nov 13, 2007 12:34 PM
roblinxs011087
Sep 10, 2007 02:07 PM
