89 Honda Civic dx wont start....
Old May 25, 2010 | 04:40 AM
winders12's Avatar
Unhappy 89 Honda Civic dx wont start....
I bought this civic about a month ago it was running fine until today. I was driving down the highway and it just died without warning and would not restart. I recently replaced the timing belt, waterpump, spark plugs and wires, and valve cover gasket. Does anyone have any idea what it could be? It has power half a tank of gas tries to start but wont.
Old May 25, 2010 | 05:51 AM
Does the starter fail to crank the engine? Or does it crank but not start? For the latter, listen for whether the fuel pump primes and check for spark at the plugs.
Old May 25, 2010 | 06:49 AM
winders12's Avatar
It cranks it just wont start....
Old May 25, 2010 | 06:55 AM
winders12's Avatar
Let me rephrase that the starter cranks not the engine...
Old May 25, 2010 | 07:32 AM
Turn the key to ON(II). Do you hear the low humming noise of the fuel pump priming in the rear (gas tank)?
Click spark link in my signature to learn how to check for spark.
Any CEL codes?
Old May 25, 2010 | 08:26 AM
winders12's Avatar
thanks ill try that
Old May 25, 2010 | 08:37 AM
Originally Posted by winders12
thanks ill try that
By the way, the fuel pump should prime for 2 seconds in the test I mentioned.
Old May 30, 2010 | 06:04 AM
winders12's Avatar
Well all the plugs spark and the fuel filter wasn't clogged I can't really hear the fuel pump so I'm guessing that's my problem.
Old May 30, 2010 | 07:09 AM
Any CEL codes?
Resolder the main relay:
http://techauto.awardspace.com/mainrelay.html
Old May 31, 2010 | 11:28 AM
winders12's Avatar
Replaced the main relay today and she fired off good as new. I can't believe that thing worked as long as did from the looks of it! Thank you for all the help!
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
cricket
20
Jan 5, 2008 07:03 PM
cam6
Sep 9, 2007 08:24 AM
cam6
Sep 8, 2007 03:58 PM
