2002 Civic EX No Oil Pressure
Old May 28, 2010 | 05:40 AM
civic2002gy's Avatar
Default 2002 Civic EX No Oil Pressure
2002 Civic EX 117K miles. Always has ran great - no problems - well maintained. Eng light illuminated accompanied by low oil pressure light. Engine vibrated. Shut down immediatley. Oil quantity checks normal. Pulled oil filter to gain access to oil switch and found NO OIL in oil filter like it was scavenged out. I am assuming that this is not a false indication and there indeed is no oil pressure. I can put a gauge on it but would rather not run it again. How tough is it to change the oil pump and do they go bad much? I wouldn't think there is many other options except maybe oil pump inlet clogged? Any input would be greatly appreciated.
UPDATE - EBD2 CODE P1361 TOP DEAD CENTER SENSOR FAULT - I interogated the EBD2 with a borrowed code scout. So if this sensor down by the timing belt is bad I am not sure how that correlates with the low oil pressure warning
Last edited by civic2002gy; May 28, 2010 at 04:30 PM. Reason: UPDATE - EBD2 CODE P1361 TOP DEAD CENTER SENSOR FAULT
Old May 28, 2010 | 06:45 AM
First off, check your oil level. Is there any oil in it? I mean by dipstick, not oil filter.
Old May 28, 2010 | 09:58 AM
oil quantity normal
Old May 28, 2010 | 11:05 AM
Take the oil pan off and inspect the pickup pipe, if it is broken or the gasket at the top is bad, the pump will suck air.
Old May 28, 2010 | 04:33 PM
Default Update - ebd2 code p1361 top dead center sensor fault
I plan to do that. Good advice. I interogated the computer just now with a code scout borrowed from a local auto parts store. I have 1 fault - P1361 - Top Dead Center Sensor Fault. Not sure how that correlates with the low oil pressure light illuminating but it would have gave the car all of the other symptoms...
Old May 30, 2010 | 04:54 AM
Got it. Changes cam position sensore from obd2 fault code P1361 and it fixed it. Thanks for all of the help.
lunger
Jul 10, 2011 02:50 PM
oilltd
Jun 10, 2008 04:06 PM
phan10m
Jul 7, 2007 04:27 PM
FlipHKD720
Apr 27, 2007 04:35 PM
