p0452 code help!!!!
Old Jun 9, 2010 | 04:14 PM
stylincompact's Avatar
Unhappy p0452 code help!!!!
hey guys im in desperate need here. my 98 ex is getting a p0452 code. ive replaced the ftps, changed 3 way valve, changed gas cap. wiring or ecu? or anything else? help!!!!
Old Jun 9, 2010 | 11:56 PM
brock1912's Avatar
Double check the vacuum connections at the tank and at the engine, there should be a diagram sticker somwhere under the hood. Make sure the connection at the sensor is clean, and that it has a ground. (Would be a good idea to check a service manual, but one wire should lead to ground.) If you get ambitious, you could check continuity between the sensor connector and the ecu. If you happen to have a spare ecu handy, swap it out and see if it goes away. Another thought, is it possible your tank has a hole in it? If there is no hissing sound when you take the gas cap off there is probably a leak somewhere.
Old Jun 10, 2010 | 12:49 PM
i checked continuity by running a wire from sensor plug to ecu and it beeped, been trying to find an ecu
Old Jun 11, 2010 | 12:30 PM
anyone?
Old Jun 11, 2010 | 01:17 PM
Did you check all three ftps wires?
Old Jun 11, 2010 | 05:57 PM
yep 1-2 was 5.12 v and 2-3 was 3.81, which honda said was ok, and then i checked the continuity from #3 to ground and no beep so that says the ecu maybe bad, but then i checked the 1-2 again and i got .05v and still 3.81 to 2-3 so im alil lost
Old Jun 15, 2010 | 06:19 PM
ok i think i found my problem, my car is originally an hx(y5) now its a y8. ecu and engine harness. some of the green ecu wires dont match(c131) should i rewire the green plug from the y5 harness? help
Old Jun 15, 2010 | 11:17 PM
brock1912's Avatar
Do you think maybe the ECU wasn't replaced? Maybe there was an engine swap but not the ecu. That could definitely throw codes at you.
Old Jun 16, 2010 | 03:07 AM
nope ecu was replaced i did it all. i just got another one to double check. that green plug 131 the wires dont match, the ftps wire isnt in the same spot when plugged in. so should i splice in the original 131 plug?
Old Jun 17, 2010 | 09:30 AM
brock1912's Avatar
Or just switch the wire to the correct hole without having to splice in the entire plug
jdtrio
Mar 17, 2010 02:52 AM
ioang26
Dec 31, 2007 08:34 AM
ioang26
Dec 30, 2007 03:33 PM
ktownjeep
Jun 20, 2007 01:40 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
