Typical 1997 rear lca swap
Old Jul 12, 2010 | 08:16 AM
GDizzle2's Avatar
Thumbs up Typical 1997 rear lca swap
Tools:
Ratchet
14mm extended socket
breaker bar
PB Blaster, Bolt loosener, etc.
Patience
STEP 1:
Loosen up rear lugs, place "roll blocker" (bricks, tires etc. anything so the car wont roll forward) in front of front tires, jack up car, place jack stands correctly, remove lugs and remove tires.
STEP 2: Once car is jacked up correctly and wheels removed. Use PB bolt loosen and spray on the 3 bolts that are going to be removed on the OEM LCA
STEP 3:
Use breaker bar and extended 14mm socket to remove the 3 bolts in the order as pictured.
STEP 4:
Look for thread to remove broken LCA bolts!!!! STUPID RUST
Old Jul 12, 2010 | 08:19 AM
StifflersMom's Avatar
Cat Fuсker
Btw no amount of penetrating lube will prevent a snapped bolt. It rusts into the bushing for good.
Old Jul 12, 2010 | 08:24 AM
GDizzle2's Avatar
aint that bout a Biscuit!
Old Jul 12, 2010 | 12:41 PM
Scott53092's Avatar
I love impact guns, use one of those before a breaker bar since it torques all around the bolt head instead of all the stress from the breaker bar being uneven.
Old Jul 13, 2010 | 05:30 AM
GDizzle2's Avatar
NOW i know. i had to take it to the shop and the mechanic had to grind and heat up the bolt to remove it. BUT!!!! they're installed now! YIPPEE!!
subnet76
Aug 20, 2008 04:31 AM
crimsonnblue
Nov 20, 2007 07:45 AM
dittoalex
Oct 10, 2007 07:41 PM
nik005
Aug 29, 2007 05:05 PM
larsenracing
Dec 22, 2005 09:50 AM
