b20b swap help
Old Jul 12, 2010 | 05:41 PM
1992 civic driver's Avatar
Smile b20b swap help
ok i have a 91 civic dx hatch back. wanting to do b20b swap. got some questions here we go. will the engine fit. what will i need. how much do you think it will cost. dont add the engine in the cost. thanks for the help.
Old Jul 12, 2010 | 07:00 PM
first this is a project thread, not a help me thread, second you need to research dpfi to mpfi conversion since your dx only has a 2 fuel injector fuel system, then you will also need to convert your car from obd0 to obd1 so you can get a ecu to run the engine, after all thats done, you will need to research b series swap into a civic.
yes it bolts up, you will need a complete motor, trans, shift linkage, ecu, axles, wire harness, motor/ trans mounts.
PhillysFinestHatch93
May 9, 2007 08:58 PM
jo7man4
Mar 20, 2007 06:02 AM
sway2003
Jul 26, 2006 07:45 PM
turbob18c1
Mar 6, 2006 08:46 PM
