Jackson supercharger fitment
Old Jul 16, 2010 | 05:17 PM
4rome's Avatar
Default Jackson supercharger fitment
Does anyone know if a jackson supercharger off a 99 hx motor will work on a 2000 ex motor?
thx
Old Jul 16, 2010 | 05:25 PM
Yes, the intake manifolds are the same.
Old Jul 16, 2010 | 05:27 PM
4rome's Avatar
Thanks
Old Jul 16, 2010 | 06:06 PM
If you are getting a JRSC, make up some sort of build/update thread, or at least pics of the install. I am getting kind of lonely being the only SC'd D series here.
Old Jul 16, 2010 | 06:36 PM
StifflersMom's Avatar
Cat Fuсker
Yer poopercharged?
Old Jul 16, 2010 | 08:28 PM
Not the greatest shot of it, but you get the idea.....
Since ~October 2009.
Old Jul 16, 2010 | 09:00 PM
4rome's Avatar
No worries. If I get it I will show you the up dates. Always some charger haters out there. It's my daily driver that I just want to get a little more out of it and I possibly can get a supercharger for a good deal. I am a life long civic guy, but I already have a boosted evo thats more than a daily driver.No need for bigger gains on the ex. Poopercharger is funny though....I'll give you that!
Old Jul 18, 2010 | 10:09 PM
Let us know if you run into any problems. I have the JRSC install guide somewhere on my PC I believe if you need it.
The hardest part was trying to figure out how the idler pulley assembly/Alternator bracket should be installed. I had to knock in my driver side strut tower wall in a little for the supercharger nose/pulley to fit, too.
When it was installed on my car, the IAT (intake air temperature sensor) needed to be changed to one from a OBD1 Civic. Just make sure you have the temp sensor getting a signal from inside the manifold. (stock 96-00 Civics have the IAT sensor in the middle of the intake pipe.) You need to be able to have the ECU "see" the actual temp of the air, so it can compensate as needed. It will be alot hotter than when you were NA.
Other than that, I remember having to grind down the coolant "port" on the back of the intake manifold since the S-pipe/T-stat housing were in the way.
What do you plan on tuning with?
Hitman
97
Nov 26, 2007 04:16 PM
SiRalex16v
Jan 5, 2006 01:31 PM
jcarp613
22
Nov 15, 2005 06:44 AM
Nail I3unny
Mar 28, 2005 11:49 PM
JrscCivic00
Jul 1, 2004 02:32 PM
