What can I do??
Old Aug 14, 2004 | 08:32 PM
OrangeCivic's Avatar
Default What can I do??
I have a d15b7 in my hatch and am looking to just do what I can with it. anything just looking for ideas I want to get the most out of it. so far I have done the intake headers and pipe but now I want to start doing things that will give me a little more. anything would help thanx.
Old Aug 14, 2004 | 09:51 PM
Default RE: What can I do??
i had the same dilema with my 95 dx coupe. if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. you should be able to get everything you need for under 500 bucks. another option is to swap in the whole sohc vtec swap, with a d16z6, all you need is the motor with all attached accessories, your tranny will work but the z6 tranny has better gearing, and the ecu, then run a couple of wires. you should be able to find everything with a yahoo or google search
Old Aug 19, 2004 | 05:43 AM
polo708's Avatar
you could always upgrade the ECU, grounding kit, stuff like that. Have you gotten into suspension yet??
Old Aug 25, 2004 | 06:03 PM
Yes everything is done but the engine. Should have done it the other way around.[sm=badidea.gif]
Old Aug 26, 2004 | 04:37 AM
polo708's Avatar
no, i was just gonna suggest that if you didnt already have it.
Old Aug 26, 2004 | 01:03 PM
NTX's Avatar
NTX
ORIGINAL: sacicons
if youre not looking to spend the money on a motor swap or FI, then look into a mini-me vtec head swap. another option is to swap in the whole sohc vtec swap
Those are your best bets. If possible, do the dohc swap.
Old Aug 26, 2004 | 02:42 PM
yeah, the immediate power gains are great with the DOHC, but the real worth of the b-series is in the potential power of the motors, you can build the hell out of a d16z6 and run the crap out of gsr swapped civics, but then they drop in a set of cams and a thin head gasket and theyll walk away from you. the best way to do it is to set up the suspension and brakes first, to handle the newfound power. i would have gone more in depth with my suspension and little stuff first, but a spun rod bearing required a new engine sooner than i planned.
Old Aug 29, 2004 | 07:10 PM
92SiR2Hatch's Avatar
Save your money and get a motor swap. That is the best bang for the buck. The best power adder for a sohc is Nos or Turbo.
Old Sep 3, 2004 | 04:39 PM
So if I was was going to do the swap what engine would be the simplest swap?
Old Sep 3, 2004 | 09:09 PM
b16a2, preferably jdm (technically called the b16a 2nd gen) or obd1 gsr. any post 94 b-series would be pretty easy. the obd1 would be easier though (and cheaper).
civicxtreme
May 15, 2006 08:11 PM
