98 civic/hard shifting 5 speed
Old Aug 23, 2005 | 06:26 AM
troutman's Avatar
Default 98 civic/hard shifting 5 speed
I drive a 98 civic 5sp manual.It just turned 100k and quite suddenly,I'm experiencing difficulty in shifting.It's quite bad when downshifting,to the point that I have to double clutch at times and even then,it's hard to get it into the next gear.It's not near as bad when upshifting through the gears and it gets better as the car gets warm.The tranny fluid only has about 17k on it.Do you think another fluid change would help and if so,should I stick with the Honda manual tranny fluid?Also,is there any history of manual tranny problems in this vehicle?I've owned a couple of civics and always thought them to be very durable.
Old Aug 23, 2005 | 07:24 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: 98 civic/hard shifting 5 speed
Do change the fluid. I wouldn't go 17K on it...
Old Aug 27, 2005 | 12:45 PM
Blackhatch124's Avatar
changing the fluid can help alot go with either royal purple or redline those two are the best
MattS93
Jan 31, 2014 02:43 PM
Jymmm
Dec 11, 2013 01:01 PM
MICAH916
May 7, 2012 01:04 PM
z_dizzlemang
Apr 25, 2008 07:52 AM
jmonkie
Oct 2, 2005 08:55 AM
