What engine is this?
Old Sep 23, 2008 | 01:06 PM
mountain_man's Avatar
Question What engine is this?
Hey everyone...
I have a 2001 Civic LX 5spd w/ 250,000 miles. The engine was replaced before I bought the car since the timing belt broke. I am not sure what engine it is. I found a number stamped on the block: A46141376N
Does anyone know what that means?
Is there anywhere to look on the engine to get a number that tells you what engine it is?
Thanks in advance!!
Old Sep 23, 2008 | 01:26 PM
pos92civic's Avatar
mine says it stamped on a plate that should be on the engine i think above the headers
Old Sep 23, 2008 | 02:42 PM
The number is on a flat place on the front of the engine, beside the exhaust manifold, where the engine meets the transmission.
Old Sep 23, 2008 | 04:53 PM
That's where I found A46141376N
Does anyone know what this number means?
Old Sep 23, 2008 | 05:21 PM
jprommel's Avatar
Angry Admin
The gods of wikipedia speak, you have the amazingly substandard d17a1
D17A1
Found in:
2001-2005 Honda Civic DX/LX/VP
Displacement : 1668 cm³
Bore and Stroke : 75 mm X 94.4 mm
Compression : 9.5:1
Power : 115 hp (86 kW) @ 6100 rpm & 110 ft·lbf (150 N·m) @ 4500 rpm
Valvetrain : SOHC
Fuel Control : OBD-2 MPFI
Old Sep 23, 2008 | 05:37 PM
macbeth18288's Avatar
wow 250,000
my 01 only has 71,000
Old Sep 23, 2008 | 07:03 PM
It should also have the "D" number stamped above the serial numbers in the same place. Since it is right below the oil filler hole it usually has a lot of oil spilled on it.
Old Sep 23, 2008 | 07:17 PM
jprommel's Avatar
Angry Admin
why does no one listen to me... =[
Old Sep 23, 2008 | 10:02 PM
civic_burns_all's Avatar
my 02 lx has 85k
any 7th gen lx and dx will be a D17a1 engine
Old Sep 24, 2008 | 05:50 AM
Because he said this:
Doesn't have to be a D17a1 that was put back in it.
