Why does this happen??
Old Oct 7, 2008 | 09:01 AM
silverbullet01's Avatar
Default Why does this happen??
my left headlight goes out when i turn my brights on. but im not sure because it may be a low beam? it doesnt look like my brights are on all the time so im guessing its a high beam. how do i make it so both my brights and low beams are both on each click? its a 98 civic ex coupe thanks
Old Oct 7, 2008 | 10:35 AM
xsteinbachx's Avatar
Your high beam could be dead. try replacing it. If it doesn't return the bulb and check for a loose wire or a fuse that's screwed.
Old Oct 7, 2008 | 12:53 PM
you cannot have both brights and lows working at the same time. trust me i tried on my old crx and it worked for afew mornings and then the bulb BLEW UP!!!!!! LOL
if your high beam is burnt out just replace the bulbs. and its best to do both bulbs at the same time. otherwise you could have the ugly car with 2 different color headlights
Old Oct 9, 2008 | 01:34 PM
sittinSideways's Avatar
I think it's because the brights are taking up too much power, but I'm not sure why the lows aren't just both dimming instead of one just going dead.
Old Oct 9, 2008 | 01:37 PM
GaMbLe_v9.09's Avatar
yeah bro you could just have a burnt out light.. replace both of them.. if problem is the same check the connector it might be cooked i know mines were fried when i had these crappy blue lights on there.. but oh well.. gonna get some HID's soon
Old Oct 9, 2008 | 02:54 PM
quick way to test the bulb is just unplug the other bulb and swap them to see if its the bulb or wiring...
Old Oct 9, 2008 | 02:55 PM
driftingfan's Avatar
Probably the high beam bulb is dead. If it is replace both highbeam bulbs. Also maybe your fuse is gone.
Fanboy_Troll
Jan 30, 2014 07:25 AM
josephdstone
Aug 17, 2009 03:17 PM
Shbek
Feb 19, 2008 02:44 PM
Fiirkan
Oct 8, 2007 02:52 PM
mill$civic
Jan 22, 2006 02:44 PM
