First Honda Civic Hatch
Old Oct 6, 2008 | 08:30 PM
mastermechanic05@hotmail.com's Avatar
Default First Honda Civic Hatch
Hello everone I have been doing a lot of reading on motor swaps and trannys,
Let me tell you a little about the honda I am getting!!!!! It is a 1990 civic hatch, d16 is the block thats the only numbers i know on it, It used to be an automatic, The tranny i think is out of a 91 manual, I was also told that the head is off an si, something called a mini swap? It is a sohc v-tech head on it, The check engine light is on, he said it is on due to the fact that it was an automatic and it is the torque converter clutch solenoid, now just to let you know I am a mechanic so I understand the basics, but not the actual honda terms and talk, I have heard that the v-tech will not kick on if CEL is on, also if this has upgraded head, wouldn't there be a different ecu in it?
Ok now for my questions;
1. Can i put a dohc v-tech head on a d16 block and what can I expect it to do,
2. If I can, I wanted to turbo it and call it good,
3. If those don't work I was gonna drive it like it is until summer and blow it and tell my wife it was really old and get I was thinking A B18? Not sure what else to get with it, I know I want it to be fast but still daily driver.
4. Which motor is the best to turbo?
5. And what does ITR or GSR stand for along with the letters after the engine code Like d16(y1)
Any help would be greatly appreciated.
Old Oct 6, 2008 | 08:41 PM
I don't believe that the 90 Civic has any transmission-related CEL codes. Perform the self-diagnosis procedure in the diagram to determine the actual CEL code:
Y_dolan
Sep 10, 2013 11:58 AM
AcXr50
Feb 25, 2011 10:55 AM
ED-EF Swaps
Oct 14, 2008 12:49 PM
Bananaboat11
Aug 17, 2007 03:36 AM
project92hatch
May 19, 2006 05:32 PM
