Stalling issues
Old Nov 13, 2008 | 07:07 PM
vtecaddict's Avatar
Default Stalling issues
So i just built a new short ram intake with a fairly large filter of my z6 and now when getting on the highway, the electrical system seems to fail when it shifts gears.. unless i keep my foot down on the pedal. does anyone have a clue of whats going on? am i pulling in too much air causing it to shut off the engine? the speedometer jumps up and down before the shutdown. No codes are being thrown and all the fuses seem fine.
Old Nov 13, 2008 | 07:25 PM
Check whether fuse 24 under the dash is blown.
Old Nov 13, 2008 | 07:29 PM
vtecaddict's Avatar
nope its not blown... unfortunately... because that would be the easy fix.
Old Nov 13, 2008 | 07:44 PM
Is the Charge System Light staying ON?
Is the alternator belt slipping?
Have you cleaned and tightened the battery terminals and connectors, as well as the battery ground wire attached to the engine bay? Have you checked whether the alternator connector is loose or the alternator wires are damaged?
Is the battery charged? Is the alternator failing? AutoZone will check your charge system as a free service.
Old Nov 13, 2008 | 07:52 PM
vtecaddict's Avatar
Alternator and battery are almost new. put new ones in like 6 months ago when i got a new motor. i got the batt and alt. checked at autozone and they are alright... ill try replacing the old ground wires with some 0 gauge power wire tomorrow at work... the air filter has a metal mesh on it and it sits right above/ rests on the starter... i dont know how but could it be shorting it out through there? isnt the fuse 24 under the dash a SRS fuse anyway?
Old Nov 13, 2008 | 07:58 PM
Originally Posted by vtecaddict
...isnt the fuse 24 under the dash a SRS fuse anyway?
Yes, fuse 24 also protects many other components related to your problem (alternator and VSS/speedometer):
Old Nov 13, 2008 | 08:02 PM
vtecaddict's Avatar
gotcha.. i didnt know that... maybe i should look at the wiring schematics sometimes...
Old Nov 14, 2008 | 08:21 AM
bcivic's Avatar
An often overlooked problem could be a ground wire loose, check your grounds make sure they are tight and on.
Bluesman
Jan 22, 2012 05:52 AM
atlantahonda
23
Jul 4, 2011 07:10 PM
PunisherInOKC
Nov 11, 2009 07:50 AM
klam
Oct 29, 2009 12:58 PM
CivicSI4
Jul 14, 2004 12:17 AM
